We have been doing some work on my boat the past few weeks. NEW COIL, PLUG WIRES, COIL WIRE, POINTS, BATTERY, CONDENSOR, FUEL FILTER, PLUGS. We finally got it started and it has started right up. Today after fixing the fuel tank out line, and changin the oil and oil filter it started up no problem.,... Ran great at 75% throttle and down .... was good until I got to where it should be running at idle and then it died. We have not been able to start it since. Took out all plugs and they were wet. Cranked it over to blow out excess (flooding) gas and re-installed them (after checking spark on each plug and wire// all were getting good spark) Checked fuel line and all filters. By-passed all filters with a stright line from tank to fuel pump. Checked fuel pump by undoing gas inlet from carb and it gets great gas flow... only thing is, is like I said it just won't fire off and start. Battery was hooked to cranking 12 v charger to ensure it wasn't it either. What couold be the issue(s)? We are lost please help. Thank you in advance.
NOTE: Plug gaps and Points gap has been set to manufacturer measurements. Trying to get my boat in the water for the 4th of July. Any and all help is appreciated.
