Re: please help..the log is still in the hull
evochick,<br /><br />I am with Crab Bait on this one, the hull should be repaired from the inside, personally I would use epoxy (remember once you use epoxy for the repair you can never use poly over the top of it).<br /><br />Remove all damaged material and make sure the area to be repaired is completely dry, do NOT use ascetone to clean, sand the patch area with minimum of 80grit sandpaper and wipe clean with damp cloth (not wet).<br /><br />The structure should be sound from the inside, I have used cross stitched matt for these types of repairs (this is woven glass with a 3/4oz backing), it is a little tough to wet out, but very strong. If you can't get to the crack/hole from the inside, you may have to cut out a piece of the deck. The outside can then be patched and fared (sp?).<br /><br />Hope this helps.<br /><br />Safe boating to all.<br /><br />Cheers.<br /><br />emp.
