gwood
- May 10, 2010
- 34
When I am using my 46# troller to reach a fishing area (no motor lake) it cuts out after approx. 5 minutes of constant use, I usually unplug & plug & it will work again for about 1 minute or so and then repeat plug/unplug. Sometimes it will pop the circuit breaker & after resetting follow same path described until I reach my destination. The troller is connected to two 12V batteries in parallel via a switch. I have noticed that this only seems to happen when I am trolling against the conditions and not with it. Does anyone have any ideas as to the problem? The troller is 3 yrs old, 1 battery is an interstate 27 deep cycle, 3 yers old and the other is an optima 27 deep cycle only 1 yr old.
