please teach me about closed cooling systems
beason
I run 100% salt water, and i know its hard on the engine, even with regular flushings. I was under the influence that a closed system required hull modification for the heat exchanger, but have recently found this is not the case, so it looks like something i could install myself.
I have a Chaparall 220 ssi with the Volvo Penta 5.0L and the DP outdrive.
so here are my questions.
1 is it worth swapping on an engine that has already been ran in the salt for a while? would there be a significant savings on replacing parts, or after run maintenance to warrant the swap?
2 is it an easy install? with my basic understanding, you put the heat exchanger inline between the raw pump and the circulation pump. separating them into two systems.
3 it seems the exhaust is still raw cooled. with the risers and manis being a big investment, i was hoping to include exhaust cooling in the system to help preserve them. is there a way to do this?
4 i would still need to flush the exchanger and exhaust correct? would the exchanger hold up to salt water for long term?
Thanks in advance.
Re: please teach me about closed cooling systems
Thanks in advance.
Ayuh,.... There's Problems convertin' motors that have a history of saltwater use,...
Salt, 'n antifreeze create a gue that plugs up everything,...
Ya oughta wait til when yer replacin' the motor, to go with the freshwater coolin',....
You Can go with a Full system, it just takes a much bigger exchanger to get rid of the manifold heat,...
'n the risers will still see Salt, as that's where the raw water is dumped,...
beason
do i need to run antifreeze in it? we hardly get freezing temps here, and i could drain the system during the short winter. does antifreeze move the heat that much better then water.
I did a little more research and found a page that explained half vs full systems.
thanks for the info!
