Pleasurecraft, 1987 v-8 carbed.
I'm not too familiar with these engines like I am with the mercs and I took the plug wires off to change the plugs but forgot to label the wires. Before I try to start it I would like to make sure I have all the plug wires in the correct spot.
The distributor is in the front of the engine, I know that probably matters.
I'm just curious if the cylinders are numbered like the mercs, with cyl. #1 on the port side and cyl. #2 on starboard side ect...?
Or are the cylinders labeled cyl. #1,2,3,4 all on port and cyl. #5,6,7,8 on starboard side?
On top of that, what is the firing order?
thank you
thank you
