plexiglass problem
whfmznb
purchased a new plexiglass windshield - the plastic/paper coating is still on it and has been for a LONG time because I am having a hard time getting it off - any tips on what products would be safe to use? Or anything I should avoid? Thanks!!!
rickdb1boat
Re: plexiglass problem
Might try heating it with a hair drier to soften the glue and slowly peeling it off.
lenny2113
whfmznb,<br />You could try product called "Goof off" or "Goo gone". They both work the same. I was able to take off old registration number using this product. Heat gun will work good also, just don't hold it for too long in the same spot. <br /><br />Good luck.
rambofish
whfmznb,<br />When I worked at the University (UNR), the machinist I shared an office with fabricated a LOT of stuff from different types of plastic materials. They all had the paper you're talking about on them..... His trick was to do all the machining, milling, cutting, etc. with the paper on and then remove it. The best way was to get a bottle of alcohol, we used eythl (100%) but 75% would work as well and soak the paper. Give it about 10 minutes and ten just wipe the paper off. And I do mean wipe it off....no peeling, scrubbing etc.... The alcohol dilutes the glue, and the wiping it off doesn't mark up the plastic. After the paper was off, you might have to wipe it down a second time just to finish cleaning a little glue residue of, but I swear this works great. Give it a try! :D
