pls help.....
wally jr
i have a 1984 bayliner w/ a 125a penta outdrive.. last year had no problems with it. it sat all winter in the water and i just bay tested it for the first time today. it runs fine, goes in to gear fine. when i went to accelerate the prop stopped spinning an the moter was winding out. i guess it dis-engages...why.......
kcole683
Re: pls help.....
Is the hub on the prop spun allowing it to slip?<br />To check put drive in gear and try to turn prop against the gear if the prop shaft stays put and the prop turns then it is spun.<br /><br />If the prop shaft turns both ways when in gear then you have some other problem(not fully in gear or worn parts etc.)
wally jr
Re: pls help.....
ps..it wouldnt be a tranny problem or something serious could it... what your saying is worn parts on the hub?
Haut Medoc
Re: pls help.....
The metal part and the center part are separated, you can't tell just by looking at it. Try what he said.J.
Haut Medoc
Re: pls help.....
If you have a spare prop put it on & se what happens.J
wally jr
Re: pls help.....
do you think it could be a major internal problem
sculbert
Re: pls help.....
Try the prop first before you start sweating. Go to a marina and ask if you can barrow a used prop or put a deposit on one for an hour and find out. It is most likely the rubber hub on the prop is bad. They are designed to fail like that to protect the internal parts of your outdrive.
