Plug and coil wires MERC 650
propwash
HI, Just wondering how i remove these wires from the distributor,do they pull out or screw out,i tried pulling the coil wire from it it but it would not come out,and i did not want to twist since they are 38 years old,also how does the lead wire disconnect from the coil?<br />I;m rebuilding the carbs and i need to get these off to reinstall the carbs,it took 4 hours just to get them out,man what a job.but i gotta keep her running since she's been so good to me.<br /> it is a 68 merc 650<br /> serial# 2448490<br /><br /> thanks ,<br /> PROPWASH.
gwmark78
Re: Plug and coil wires MERC 650
Distributor wires unscrew and coil wire should just pull out -usually a little coaxing required.
propwash
Thanks, i'll see what i can do.<br /><br /> propwash.
