Plug Difference
sharkeydude
I have a 1995 Mercruiser 3.0LX and it calls for the AC MR43TS plugs. Can I use the MR43T plugs? Is there a huge difference?
Don S
Re: Plug Difference
You should be using an LTS, not a TS. AC MR43LTS it's a long reach plug the T isn't.
sharkeydude
Re: Plug Difference
Thanks Don. However, the guide on the motor specifies the TS plugs. So, I'm a bit confused. The TS seems to be obsolete because have found none. I have found the NKG replacement and don't want to use the Champion. I just don't want to damage my engine by use a longer plug than specified. Could you shed some more light, please?
Don S
Re: Plug Difference
What is the serial number of your engine? There were some engines that had the decal changed because of wrong information.
straightleg
Re: Plug Difference
Wow!! how could you know that.
Must have been around engines along time for information like that.
Gerry
Don S
Re: Plug Difference
Found both bulletins, one was for wrong firing order, the second for wrong timing, but both much newer engines.
You need the MR43LTS spark plug for a 95 3.0LX. By the parts lookup, and by the service manual. There has never been an MR43TS used that I am aware of. Obviously your info on your engine is incorrect, or the L is missing.
sharkeydude
Re: Plug Difference
The serial number is 0F419592. Wow, I never would have thought that a typo like that would be able to leave the manufacturer! Thanks for all the info, Don.048.jpg
Don S
Re: Plug Difference
Let's put it this way, there is no such thing as an MR43TS spark plug, so it's not really a big issue to stop production because of a mistake on a decal. The worse that can happen is you have to look at your owners manual, the service manual, or even contact a Mercruiser certified dealer to find out what you should have.
fat fanny
Re: Plug Difference
Don os correct on all counts. I have the same exact set up as you and my flame arrestor cover states MR43LTS never used anything but.
