Plug numbers: Which should I use?
Big Al1
I was going to replace the plugs in my Merc60 6hp, 1964 model, and the current plugs are Champion CJ6 I beleive. The manual says CJ7. Are the numbers temperature related? Do you think that Mercury updated the plug recommendations? Does the 6 rating run lower temperature or something? My plugs always seem wet like not all of the fuel is getting burnt. I have rebuilt carb and fuel pump and lines.
Jack Shellac
Re: Plug numbers: Which should I use?
Your best bet is to always use the plug recommended in the manual unless you have a special situation. For example, if you do a lot of trolling, use a hotter plug to keep fouling down. The plug in the manual is for all-around average use.
