Plugging the block dipstick hole.
Tyger23
I'm replacing the 4.3 and my block arrived with a nice warning tag that I needed to block off the dipstick hole if not using it. Well, I'm not using it.
I purchased a 3/8" freeze plug from Napa (Part #: SEP 3812185) and installed it with a little Permatex #3 Aviation on the sides. I used a flat rod (actually the mounting rod that goes between the trim rams on the outdrive) to hammer it in flush. Then I used a 6mm socket on an extension to recess it.
Is this sufficient, or do I need to add some RTV over the top?
12egc7y0ruiDmZGH44KqsqobyJt83u9koSMpQxHROp4WNmTcbqKDH5IREivKQlX84f86IauadCNGY4h0D8jzNEyTKj3Kwl5ufUy_4MIOfuSWjYxOwCcuj90r2f1FVwYAXVE2hH_sBab8qI37ii1wB9MF9VqOA7761R3dV9Df8EFkxfOg9unJncIMU61OarAkIaRlQeaRZou4WE7LPmimhhC3_NbtWqNnPdzS_LpqEtvB169WYixO3nLk4ss8g9r2eZDOK6iEN7GjA5D9esZUtyb3FGPJkfzFBgiPHNXSialwM7JiBfZ9TtZdDPJQ5wlXhmNbn4mQ4uW158fHKDu6EmoipWyyvn57paozYBsL0Y0xZwF6NPEtmRTqm02fE75vLxtThbL5HZ7GFUWF7IOtJ0kz-z3uS4BmTA_dkCMqNuO6F_xHgAtNf6trL6OiX0nPuH1OwjLbyxOFSKPbiOTAGHFMPYvhBnNN_C977AEOBZrfdREkhN2_4ktnY67FI1f0Xu58AV12Gjvsb6td4vPaSa7Tv2r3lhjgoQSOuCd1Ak04IQpAr7sbOUXuMJ9cH946rNa4hOoc9CqMHntrLYNVRSD7QYVV5t_pLDKkfU60aNKYatl3Yxo1nf0zK9nMyfAyek0ru7q92a8-6lIJwKUAEJTA7UDZjkPKNcoimNV2sUVGoGVwMPapFvJ35JKLhLU-nuJM-zDeEIm1ArM7_-8xXnibI0wCTmihZ3DKv72JTeznEXUDfn_jhQ=w1184-h888-no
your fine, however I would paint the motor before you install it, then hose it down with fluid film after.
the black "primer/paint" stuff they spray the motor with really sucks as a marine coating.
