It is for the same reason that typically only one piston melts when the engine is run lean.
Depending upon engine and manifold design, One cylinder will always run just a bit richer than the other. If you set the carb for best idle and most efficient running, one cylinder will be lean and depending upon setting, it will eventually or immediately suffer damage.
