Plywood and coating recommendations for Spira Robalo Junior Panga
dlptoo
Hi! I'm a first-time boat builder and thoroughly confused and questioning my sanity at deciding to build a boat...
I live in Spokane, WA, and have wanted a boat for years for fishing and touring the lakes and rivers around here. We don't get a lot of rain or humidity, do get snow and below freezing temperatures, and have nice warm summers. It can get very windy around here, which does create some decent sized waves on the lakes and bigger rivers. I say that so you know what I want to do and the type of weather we get around here, in case it matters in regard to responses.
I've decided to build a Spira Robalo Junior Panga (https://spirainternational.com/hp_roba.php) and have been reading up on what type of plywood to use for the hull and how to waterproof it. The more I read, the more confused I get...or I draw the conclusion that it doesn't really matter what I use.
I'm 65 years old, and this will probably be the only boat I'll own. I want it to last at least 10 to 15 years, and I'll probably be putting a 25 hp outboard on it. Most of the time, my wife and I will be the only people in it; but there may be a few times when there are 3 or 4 people in the boat. The boat will usually be used for day excursions, though there will be a few times a year when it sits in the water for 2 to 3 days and maybe once a year when it stays in the water for a week or so. When it's not in the water, it will be in our garage.
So, first question. What type of plywood should I use for the hull? I've read various opinions that it must be marine grade. But some people don't like marine grade Douglas fir because it supposedly "checks," whatever that is. Some people prefer Okoume. Some people say regular exterior plywood is fine. Some say not to use hardwood nor interior plywood. Jeff Spira suggested that I could use interior hardwood plywood such as Sande plywood (https://www.homedepot.com/p/12mm-Sa...ual-0-472-in-x-48-in-x-96-in-454532/203414055). The opinions are all over the board. And, of course, I'm asking for more opinions...:) My inclination is to go with Okoume marine grade, but it is considerably more expensive. Is the cost worth it?
I've also read varying opinions on how to waterproof the exterior and interior, from just painting it well to using fiber glass on both sides. Some people say that all the framing should be coated with up to 3 coats of epoxy, others say to cover it with something like Thompsons Water Seal, and others again say just to paint it. If you do epoxy everything, do you do so to the individual pieces before you put them together for the framing and before you attach the plywood, or do you wait until after the boat is assembled? So far, I'm of the opinion to fiberglass the outside as per Jeff's instructions with 2 layers of 6 ounce cloth. I was going to epoxy the interior after I assembled everything until I read that that can have an adverse affect by keeping the wood from breathing. So, I'm not sure what to do with the inside. Regardless of what else I do to the interior, I do plan on painting the exterior and the interior.
Any thoughts on all this? Thanks, in advance, for your help!
Don
kcassells
Welcome aboard!
Good place to be and ask away. Take lots of pics and measures and post them, they guys can really help you better.
As far as woods its like this;
ACX, BCX,CDX Exterior grade plywood. Not treated lumber or ply. Ea. grade typically represents the voids to anticipate when you cut it.
Ply is structurally stronger than lumber/dimensional.
-From there you can buy up into marine grade plys and composite materials. All have pros and cones with elevated pricing.
-Most here go with plys referenced cause were smart, cheap or broke. Installed properly your grandkids will be using the boat.
-Most use poly cause most boats are built with poly poxy. Personally I use EEEpppOOOxxyy. Cause I like it and costs a penny more.
-You cannot waterproof a boat with just paint. You will roll it with whatever poxy you choose. It will need to be wet out, sealed and let dry then a paint or gelcoat. Gelcoat and EEppoxy don't get along to well. But good with paint.
-Oh yea.. bag the interior sand plywood. Can't recall a boat builder being that dumb to recommend it. Everything is exterior. Imagine a kitchen cabinet sitting in your boat for a year. PILE of mush ya see.
Kevin
matt167
Generally boat builders are somewhat snobs when it comes to the wood type. They will tell you to use woods like Meranti and Okume which are imported plywoods specifically manufactured for boat building. There are more inexpensive versions of these exotic woods but you will still spend 50% more than domestic materials..
I have a boat built out of 1/2" CDX, however it is a cheap build, not a planing hull and not really a conventional design.. Okume or Meranti would be overkill for mine If you are following actual plans, the Meranti or Okume might be what you want.
Home Depot in my area sells Exterior grade BCX for like $20/ sheet in my area. It's SYP and not DF so it's a heavier product. I used the CDX product as I was re sheathing a house and ordered extra sheets, otherwise I would have used the SYP material as it's a better product, probably good enough for you to use if your after a 'work boat'
mickyryan
Spira is a complete process , he assumes you will use epoxy and thats the strength and longetivity regardless of wood used as the wood is supposed to stay dry.... thats a cool little boat i i w going to build the deadrise he has plans for but i have issues here with carpenter bees destroying anything i build out of wood lol
dlptoo
Thanks, guys! Your comments are reassuring.I went by a supplier of marine grade plywood in town over the weekend. Comparing their marine grade Douglas fir and Okoume, the latter was much thinner than the DF, especially the 3/8" sheets called for in the plans for the sides of the boat. I'll either go with ACX or the marine grade DF.
I will post pictures along the way and, I'm sure, ask lots of questions.
Thanks for your help!
Don
