Hi all, my saga continues trying to get this thing running good. I have spark and compression and fuel but it only runs intermittantly.
Here is my latest question. I am checking my point set continuity, SELOC manual says to add another timing mark to my flywheel 1-3/8" from existing mark. When measuring continuity between the wire to the point set and starter solenoid, I should break continuity when I am aligned with original mark, then again when aligned with added mark. Indicating the first set of points and then the second set of points have opened and closed respectively.
When I do the test, I break continuity all the way between the two marks, I do not have continuity between the marks ( counter to what my manual says is correct) .This happens as both point sets are open over this stretch of flywheel rotation.
Because the points are wired in a paralleI circuit, the only way to break continuity is when both point sets are open. I am thinking the manual is wrong on this when it says one point set opens , closes and then the other opens and actualy my points are OK as is. Then again perhpas I am wrong and I have a short somewhere or something.
Please let me know if you know how the test for this should be done and if I am missing something.
Thanks for the help.
