Points Kit and Felt Pad
kayakman12345
I bought new points kit and it comes with 2 capsules of Oil....what do I put it on? Anyone Know?????
Also I noticed a felt pad that rubs on the drive shaft just behind a coil does this pad need to be oiled while I am changing the points, condenser and coils?
Thanks
ENSIGN
Re: Points Kit and Felt Pad
The pad is where you put the oil only use a little! If there are any pivot points or advance weightsput some on those to.
smarks
Grease capsuls are used on the little cams in your distributor. Just smeare a little all over the dia of the cams. Regards
Steve
