Just bought a boat and the old owner tells me the points wear out after 10-15 hrs . Coil labelled 'use external resistor'could not find one installed so i put a ballast resistor on the positive side of the coil. Start engine and their is 10.5 v @ idle and 12 at a high idle,everything i read on the net tells me i should have 6-8 volts when running am i wrong?It does appear to start easier after the resistor was installed and it is coming up on 15hrs of running time.Do you think my problem is solved or is the volts still to high and the points are going to wear out??Maybe their is anoter reason for the points to wear out ? I have not experianced these wearing out yet as i have only used the boat a few times .
