brotherkicksave
- Jan 17, 2012
- 36
I need help. Has anyone had success with sanding scratches out of aluminum pontoons? Sanding and then polishing?
On the bottom rear of the center toon there is a drain plug grommet. My understanding is that...the hole for the grommet was drilled too large from the factory. My dealer replaced the grommet with larger size, resealed it and no more leak. The hose is to drain any moisture that has gathered around the fuel tank. That hose is connected to the tray where the fuel cell sits on it/in it. And there is no bilge pump. Hope this helps.
