guy48065
- Aug 31, 2008
- 536
I have an 18' pontoon with a 2000 Johnson 40HP (J40PLSSM). It's a pretty short run from the OB to the helm and there's several feet of harness just coiled up in the motor pod. Is this normal setup? Are these harnesses "one size fits all"?
Previous owner chopped the harness inside the console so I have no gauge feeds. I'm weighing whether to replace the entire harness with new (or good used), or just pull some of that extra into the console and install new connectors for what I need (planning to add some gauges). I do have the tools & skills to install the Deutsch connectors. The problem with the cheaper solution of pulling some of the unused harness is then I will have to do something with the extra length of the part of the harness that pops up thru the floor boot at the back corner and runs with the shift & throttle cables to the remote.
A 3rd option would be to just solder new wires to the chopped ones in the console.
I don't know squat about dealer setup and have never scrutinized other boats to compare.
