MichaelMullis
- Sep 18, 2003
- 131
Does it matter which direction plywood lays on support beams? Does the 8' side have to go across boat or can it be run length of boat. It will take the same either way but I think that plywood is stronger when laid across beams length wise. At least thats what I was always told when I was in the construction trade. You always see ply run across rafters not up rafters. <br />Also, is there any reason why steering center is placed at rear of boat? I would like to set mine in the front part of the boat. I know it means longer cables, but is there any other reason not to move to front of boat.
