pontoon dock
Jaideep
Hi I have a long pontoon dock and one of the pontoons seems to be not gloating as well.
can I add air or is there water in the pontoon that I need to remove?
help would be appreciated.
Thanks
welcome aboard
most likely you have a leak and its filled with water.
you will need to empty the water, fix the leak, and then re-install the plugs/caps, etc.
Ayuh,..... Welcome Aboard,...... This, ^^^ is my guess,......
If you put air to it, don't go over 'bout 5 psi, or yer buildin' a Bomb,.....
'n if you don't fix the leak, you'll be right back in the same place, in short order,....
