Pontoon Engine Shaft Length
bjg427
Hey, I'm trying to figure out what engine shaft length I need for a replacement motor on a 2003 22 ft. Sun Tracker. Can't seem to find the info on the web...thanks for helping
jbcurt00
BJG please dont start multiple topics in multiple forums about the same subject.
This pontoon forum likely has more traffic then the Sun Tracker forum, so I closed that topic.
What length shaft is on the boat now? Replace it w the same shaft length.
ahicks
To my knowledge, short shafts haven't been used on anything but small fishing boats for quite some time - 70's?
Cat nip
Measure from the top of the transom pod to the bottom of the transom pod and if its closer to 15" its a short shaft, if its closer to 20" its a long shaft. Keep in mind there is about 2" of adjustment in the motor mounting holes.
