The Jungle Cruise
- Apr 16, 2003
- 20
Hello, I currently have a 1985 Sylvan 19 ft Pontoon Boat with a 1990 25hp Johnson Outboard. The problem I am having is with the Motor Mount. It has a design that I have not seen on any other Pontoon boat and Ive looked at a hundred. It currently has two angle brackets that go 3 ft under the boat and stick out another ft. The brackets are welded to this huge box that is 3 ft wide and 2 ft deep by 9 in high and has pivot brackets on it to manually adjust the trim. The mount keeps breaking at the weld point. Ive had it re-welded twice, stupid me never realized I needed to support both the motor and the mount while traveling, I only did the motor. The mount has not broken again, but its bending badly at the weld point and I want to scrap the whole thing. Ive done quit a bit of searching on the web and even called Marinas, Boat Manufacturers, Boat Dealers and Marine Salvage Yards. So far no luck, everyone keeps telling me I need a jack plate, which I do, but I also need to mount the plate to something. The most common design I have seen is a V bottom type design that sticks out the back of the boat about 12 in. Does anyone know of a good place to pick one of these up, or am I just better off fabbing my own? With my current configuration do I even need a jack plate, or am I ok just mounting it in a fixed location? Im thinking about moving up to a 40-50 hp motor, should this have any impact on my design. Well thanks for reading my chronicle and as always, any help will be appreciated.<br /><br />Thanks,<br /><br />Mike<br /><br />
