I have a 20' Voyager pontoon with an Evinrude 88 SPL without power trim or tilt. I have been having some problems with cavitation that I have almost completely cured by lowering the motor two holes on the transom plate and moving the trim pin to the second to last hole (furthest from the transom). When I trim it any lower, the front of the boat drops down once I get up to speed and pulls the motor up, then the prop starts slipping. Should I go ahead and drop the motor to the lowest hole on the transom? I was also thinking about buying a CMC power trim/tilt unit. Anyone have experience with one of these units on a pontoon? Would the 6" set-back of the trim unit help with cavitation? According to the CMC website it would.<br /><br />Thanks
