Pontoon Prop Replacement
Bennettc
Here is my info. Any suggestions on what prop I should move to?
ESSENTIAL DATA REQUIRED
1) Performance issue you are trying to correct. Less strain on motor and more speed with full load.
2) Current prop manufacturer, model, aluminum or stainless as a minimum. Michigan aluminum-386909
3) Current prop diameter and pitch (required). 12.5 x 13
4) Wide open throttle RPM and speed with an average load (very helpful) 6100-6300. 14mph
5) Engine/drive make, model, year, and HP johnson 40hp 1990
6) Boat make model, year, length and weight Tracker Bass Buggy 18ft
