Pontoons leaking
lncoop
Re: Pontoons leaking
It's surprisingly inexpensive to have your toons pressure tested and repaired. Check around for a welder that specializes in boats. Not just anyone can do a good job on aluminum. Your local boat shop may have one on staff or know of one. This is the right way to do it. Good luck and welcome aboard.
Bob_VT
Injecting foam into pontoons will not solve any problems and will create more. Foam absorbs water over time and you will have a worthless boat.
You are better off finding and repairing the leaks.
