I've checked the compression on my small Evinrude 4,5 HP Kicker and I read only 70-75 PSI per cylinders after 3-4 cranks. It is really low. Used to have a 2HP and it had 120 PSI in the cylinder.
Even my good old Lark VIII 40HP '66 has 110 on both cylinders and runs A1.
I have a felling this is why it smokes blue a lot, I've cleaned the carb, engine with an engine cleaner, ajusted the low needle valve and nothing changed even after a good 4-5 hrs after the tune-up. Also the spark plugs are full of carbon deposits.
What should I do? Do more or change it after this season?
