Poor runner
mark.24zg
Hi guys,<br /><br />Engine: 70hp, 3 cyl, 1982, thunderbolt ign.<br /><br />Mech recently checked the engine said the fuel pump was only pullin 1lb instead of 3. Ran the boat after its check, everything fine. Following trip the engine back to its old tricks of boggin down at WOT, I've noticed that the speedo can also fall to zero.<br />Cleaned out main carb jets<br />Tank is vented<br />Fuel filter empties and syphons fuel back in when engine is shut off.<br />Prima bulb goes soft.<br />Fuel lines seem.<br /><br />Are these signs of a electrical prob.<br /><br />Thanks for reading<br /><br />Ta<br /><br />Mark
LubeDude
Re: Poor runner
No, these are signs of a bad promer bulb and bad fuel pump. Get new ones and I think your troubles will go away.
randycc58
Re: Poor runner
I had similar problem at wot. on my 150. I rebuilt the fuel pump today and it solved my problem. Although I did not have the primer problem you mentioned. I would first replace the primer bulb. It sounds like the check in it went bad
mark.24zg
Re: Poor runner
Thanks for your replys. I have bought a new primer bulb and it has been installed, hopefully try this weekend following a new paint scheme.<br /><br />Will keep you posted.<br /><br />Mark :)
