I have a 1977 Merc 700 EL (70HP).
It doesn't want to start unless I put some petrol into both carburettors, once started it runs fine at mid and high rev's, however on approaching idle speeds the rev rate gets variable and eventually it cuts out. The engine sometimes restarts okay when warm.
All three cylinders run at 125PSI when warm and 120PSI cold. The sparks seem a little poor, but I am not familiar with the plug type (no electrode) so I don't know whether this is normal. I am using a 50:1 mixture and has used a carb cleaner additive twice with the last two tanks with no effect. There is a airlevel in the inline fuel filter which I can't get rid of it is about 1/3 of the height.
Any suggestions, I would like to avoid an overhaul of the carburettors and fuel pump, without a strong or definate reason
