poppet valve
shaenjay09
does an 87 3.0 alpha one i/o have a poppet valve and if so were is it located?
Re: poppet valve
Ayuh,.... Donno what you're talkin' about,... So,.. Nope....
What's the Problem anyways,..??
Don S
Re: poppet valve
Ok, I have to ask, since most of the time, questions like this come up because you have used the search function looking for a cure to a problem and ran into a word you don't understand.
So what exactly is your problem?
To answer your question, no, there is no such thing as a poppet valve on your engine or drive.
JustJason
Re: poppet valve
Poppit (or pressure) valve is something thats typically used in outboards only, and not in IO's.
