I have a 1988 Bayliner Bass boat on which I used to have a Force 125. The Force gave up the ghost and I was fortunate enough to find a 1981 Evinrude 140 to replace it. The Evinrude has great power, starts easily and runs very smoothly at all speeds. My problem is that when I take the boat above 3500rpm, it begins to porpoise. I have tried to trim out the engine, but it won't smooth out, only gets worse. The only way I can get rid of the porpoising is to back down on the RPM to about 3000. Then the boat runs smooth as glass. When the Force 125 was running, the boat would not porpoise, even at top speeds. I suspect that there is a trim/tilt adjustment that can be made with the engine mount. I am including pics of the engine mount so someone may be able to help me out. Picture 2 shows that there is one lower adjustment for the tilt(?) but it is more difficult to see the adjustment hole in Pic #1.
