crashkaloop
- Jun 5, 2013
- 54
Different Compression on each Bank
I know the possible causes of one cylinder being low on compression, but what about the entire bank being low? My port 3 cylinders are all lower than the starboard bank. These test were completed at 6,000 foot altitude, so they may all appear to be low compared to what would be expected at sea level. Here are the testing conditions.
6,000 altitude
Seafoamed all three port cylinders day before test
New plugs
Engine warmed up run hard for ? hour
All plugs removed
Kill switch clip removed
Throttle wide open
Compression tests done twice
And here are the results:
Port
Cyl/Lbs
2 - 100
4 - 88
6 - 95
Starboard
Cyl/Lbs
1 - 110
3 - 105
5 - 110
Ok, this is showing up nothing in the post like it does in the posting window.:blue: Sorry, trying to fix it.
Does this point to some common problem on the port bank? I realize that all three of the cylinders could have a problem each, but does this point to a head problem or head gasket or something? Are there any other test I can do to isolate what may be the problem? The engine starts and runs just fine.
Thanks for any possible solutions.
6,000 altitude
New plugs
All plugs removed
Throttle wide open
Port
Cyl/Lbs
2 - 100
4 - 88
6 - 95
Starboard
Cyl/Lbs
1 - 110
3 - 105
5 - 110
