I posted about this topic a couple of days ago but I am not able to find the post, apparently it was deleted during all of this maintenance work. Anyhow, I have a 3 gallon plastic portable fuel tank for my motor. I noticed a couple of days ago that gas was leaking out the end of the hose (while not connected to the motor). If I loosen the tank lid and relieve the pressure it quits leaking but once the pressure builds back up in the tank it starts leaking again. The pressure build up is from the heat ( store in my storage building). The tank has a built in vent in the lid. My question is, do you think that the leak is a result of a bad or clogged vent or do you think that the valve in the primer bulb has gone bad. The tank, hose and bulb were all bought about two years ago. I you think it is the vent, what do you suggest that I do?
Thanks
Thanks
