backyardhockey3
- Oct 13, 2010
- 55
Any rule of thumb on this, like how far back from main poles?
You want the rear support poles to hold the top at the proper position when under way, which is the leading edge of the top must be slightly lower than the rear when on plane, otherwise the top will act like a parachute , flapping and rocking back and forth. The way I install mine is to use the front straps to find the right position, then extend the rear poles too the spot that works the best without changing the angle of the top.
