Hi all<br /><br />This engine started to stall when given throttle but ran fine at high rpm, slowly got worse and now only runs on muffs in the driveway. I have checked comression, about the same on all 3 cylinders (90 psi), it has spark as tested with spark tester, and, since I did not know what else to do, I have rebuilt carbs (twice) and replaced the powerpack with an auto ignition coil but still same problem. I have now noticed that the lower (# 3 cylinder is not firing at idle speeds on muffs in the driveway) When I put my hand in front of the carbs, I noticed good sucition on the top cylinder, ok suction on the middle cylinder and no suction on the bottom cylinder. I can squirt premix into this third cylinder and it just pools there in the front part of the carb. Since compression is good, I am suspecting the lower seal on the crankcase. <br /><br />Is there some better way to diagnose this before I start pulling off the powerhead? <br /><br />All help is greatly apprectiated.
