possible boat issue? or may be ok?
scon
at WOT i can only reach about 3800 rpm sometimes 4000 its a 305 inboard w/alpha one outdrive....whats the highest rpm i can turn my alpha one safely and is there a prop calculator and if i change my prop will that help me gain mph? its a 21p prop now
Don S
Re: possible boat issue? or may be ok?
Have you tried trimming the drive up?
scon
yes...the gauge is not rowking correctly but about 7 clicks up seems to be my formula for best results......y will it go faster up stream then down?
6meter
A sbc runs WOT in the 4600-4800 rpm range. Check the sticky at the begining for the diagnostic chart for WOT.
