would like to know if you take off hose at raw water pump part number 3857794 the larger hose...if you put the water hose flush system or out of water running system with the water ear muffs should the water come out of the hase that I disconnected from raw water pump or is there some type of valve or mechanism between where you put on waterhose connection and hose to waterpump???t... no water came through when I did this also I am not getting water circulation in raw water cooling system need to find this out before buying new water pump or replacing impeller.. if this got clogged up what can I use to clear line???
