bluemarshboater
- Jul 6, 2009
- 118
I have a lower unit that went bad do to no lube. Upon inspecting the old unit (came with the boat) and the replacement they are different. The original one has what seems to be an oil passage from upper to lower (see attachment please) and the new replacement does not. The lube in the upper unit is nice and clean, no water, and didn't feed the bottom unit.... only when I removed the lower unit did the top drain down. Before pulling the lower unit I removed the drain plug on it to find 90% water (maybe 4 oz or so) and probably what the manufacture has put in the unit before delivery.
Best
Dave
I'm working on a GEN II (don't know serial, where can that be found?)
Best
Dave
