Hi, I'm new to the forum and own a 1990 Sunbird Corsca with the 4.3 OMC Cobra I/O. I took the family and boat to Lake of the Ozarks for vacation last week (its first time in the water this year). The boat has been well maintained and was in good running order before taking the trip. The boat ran fine the first day. The next day it ran fine and that evening we piled in the boat to go have dinner at a restaurant on the other side of the channel. When we left the restaurant after dark we idled out with no problem. Once I passed the No Wake and gave it the gas but it stumbled badly and died. It restarted and idled but died again when I tried to accelerate. It would not restart. We were fortunate to get a tow back to the restaurant and tied up. The next day I drove to that location, loaded the boat.
Since returning home I've replaced the fuel/water filter, checked the anti-siphon valve at the gas tank, check the vent line, and checked the small screen filter at the carb. Also, the gas doesn't smell bad. I'm suspecting the fuel pump due to erratic test results. When I first put the fuel pressure gauge on the line it only read 3 lbs per sq. inc., I then tried to observe the volume by directing gas into a cup... it barely moved any fuel. Approx 15 minutes later I repeated the test, this time it read 7 lbs per sq inch pressure and the volume was very good - it filled the solo cup in about 20 seconds. Tonight I tried the test again, it read 4 lbs per sq inch and the volume was reasonable but clearly less than before. I also checked to see how much vacuum the fuel pump was pulling at the gas tank outlet... it was a consistent 6 to 7 inch pounds. I know that a car's mechanical fuel pump to run around 7 lbs per square inch but don't know if a marine pump is any different. Is it common for a fuel pump to have this range of readings?
Also, I'm really surprised at how much more expensive a marine 4.3 fuel pump is compared to an automotive 4.3 fuel pump. Can an automotive pump be used instead? All things being equal I'd prefer to save the $100 difference.
Thanks in advance for any advice...
Gary
Gary
