Possible metal piece in gear housing
Milo1105
Hey I was trying to pry control shaft seal out and my lunch tip broke off and I’m unsure if it fell in, I have spun gears and don’t feel any binding , any tips ? Was told never to remove screw on back and I think I have to to gut gears
Nordin
See you have a screw driver in the hole where the pivot pin screw should be.
But to put the shift rod back you have to disassemble the gear case as the shift rod has to be threaded back into the gear shift arm.
