Possible uses for shredded paper?
Status
Not open for further replies.
Kalian
Hey everybody. I have been shredding my junk mail at home. I have been wondering what you guys who shredd unwanted papers use the results for.<br /> I don't have a woodstove or fireplace, so I recently decided to start a mulch pile with it, although the glossy paper might not work out. Anybody else use it for anything, rather than throw it out?
Drowned Rat
Re: Possible uses for shredded paper?
Use it for packing material for sending packages.
ZmOz
Originally posted by Drowned Rat:<br /> Use it for packing material for sending packages.
I hate it when people do that. It's much heavier than other packing materials and makes a mess on the other end.
KRS
Banned
Paper-Crete<br /><br />Mix and use as a plaster for exterior surface finishing (homes, fences, etc.)
Homerr
I shred my papers too. Then I burn it in the burn-barrel. Total 100% destroyed that way.<br />Been there, done-that with ID theft.<br /><br />I wouldn't send it as packaging. I agree... too heavy and messy.<br /><br />Burn it if you can and toss it on the mulch pile. That will make its 'circle-of-life' complete.<br /><br /><br />H.
Drowned Rat
We save the plastic bags they deliver the newspaper in and stuff those. I guess it is heavy though, but it doesn't make a mess.
Bassy
Originally posted by azfyrfyter63:<br /> Paper-Crete<br /><br />Mix and use as a plaster for exterior surface finishing (homes, fences, etc.)
Exactly! Hey, we're going to attempt paper-crete on our room addition exterior. Wish us luck.<br />Bassy
Box it and send it to Bassy! ;)
Bassy
Originally posted by Link:<br /> Box it and send it to Bassy! ;)
You got that right! Send it on to me! We need lots! <br />Bassy
Nos4r2
Depends how shredded it is. If it's not dust it makes good pet bedding, if it's really fine if you mulch and compress it then leave to dry in blocks it can be used as logs for the fire.
rolmops
I used to buy it by the ton and use it for bedding in my barn.
Anybody heard of recycling? Or is that an environmentalist way? :eek: <br />Standard Disclaimer
KilroyJC
If you have any soil erosion problems on your property, that'll help.<br /><br />If you have any oil leaks under your vehicle, put it in an onion bag, then put it under the leak.<br /><br />Also works well for cleaning up spills, or spreading around when cleaning engine parts to catch gunk.<br /><br />If you have a shed, you can sheetrock the interior, and cut access holes at the top between studs. Pour it in for insulation.<br /><br />If it is the cross-cut type shredder intead of the long strip cutter, then you have New Year's Eve Confetti!<br /><br />Don't know if this applies to you, but you can give a BIG box of it as a gift you the pre-school age grandkids...
Originally posted by KilroyJC:<br /> <br /><br />Don't know if this applies to you, but you can give a BIG box of it as a gift you the pre-school age grandkids...
Considering your signature I know you know what you are talking about, but I am a confused by the use of a pronoun in place of an article. ;) <br />I was sure the recycle comment would have brought a raft of disparaging remarks. Since it did not let me explain recycling to you: Seperated all trash into appropriate classes. Keep until you are stumbling over it. Load it up in the pick up truck and take it to the nearest recycler (fifty miles away in a truck that gets 14 miles to the gallon) Take the proceeds and buy gas for the truck. Call the auto club for enough gas to get home... :D
ndemge
Call local animal shelters, free bedding is always a great thing. <br /><br />And if all else fails, FREECYCLE, someone will take it.
Kenneth Brown
Originally posted by technoquiet:<br /> Load it up in the pick up truck and take it to the nearest recycler (fifty miles away in a truck that gets 14 miles to the gallon) Take the proceeds and buy gas for the truck. Call the auto club for enough gas to get home... :D
Real trucks don't get 14 mpg, they get 14gpm
ndemge
14 gpm? your Lucky!<br /><br />I havn't been able to drive my truck, I left it running at the pump, and the pump couldn't keep up, and they ran out of gas at the station, not getting any more delivered until next week.<br /><br /><br />
Status
