Possible water in gas tank
Bene288
Should probably be in FAQ engine discussion but it wouldn't let me post there.
Anyway, My gas cap was not completely covered for a week or so and we've had some rain since then. Does this get treated with mineralbase spirits or dry gas like in a car ? I know a flush is the safest route, just trying to get around that if possible.
The engine seemed to turn over fine with muffs, just being cautious.
Bene288
Re: Possible water in gas tank
That seems like a good idea for the future. I know alcohol based spirits pull the water and burn off, I just wasn't sure if that was good for a 2 stroke engine.
180shabah
Water seperator, get a couple of spares. Run the tank empty if you can, or as close as you can if you can't run from a secondary tank.
