Re: PossibleNew purchase worried about engine size with skiier
Hi lsdempsey,
I own a 2007 185LX with the Merc 3.0 135hp...similar engine and outdrive, stock aluminum prop, and Smart Tabs. We normally have 2 adults, 3 kids. I've had 4 adults (between 135-220lbs each) and 4 kids (between 70-90 lbs each) in this boat at one time and have had no problems pulling a tube. Closest I can come to a real-life example of what you are asking was last week. We had 4 adults in the boat (all between 135 and 220lbs) and one adult skiing (190lbs). I was able to get him up on one/two skis. What your dealer told you was accurate. I'm sure more power would pull better, but I got what I could reasonably afford and am happy with the results. I would get the same thing if I had to do it over again. Hope this helps.
