1975 25hp Evinrude. Compression is 120 and 125. Spark jumps 7/16" on tester. Engine absolutely will not even try to star in water. If I remove it from barrel, pull plugs and drain all left over fuel...Basically dry it out really well. I can sparay some mix into carb and it fires right up. Only thing I think of is water getting pulled into cylinders. Any other possible way water can get there other than head gasket?
