POSTERS!!! More engine info
clanton
Evinrude/Johnson has made a lot of different engines over the past years.
It helps to know which engine you have. Id the engine by model number if you have it, number of cylinders, 60 degree, 90 degree, looper, crossflow, 4 stroke. The 60 degree engines have an optical ignition trigger, different from all of the other engines.
