Potentiel Expensive Mistake Upper water pocket cover
jaxsez
It looks like I am learning an expensive lesson. I just followed my seal guide and I attempted to replace the upper water pocket cover seal. Of course while putting one of the bolts back in it broke off while installing it. There is nothing even to grab onto to pulled it back out. I would have to try and drill it out and extract it. I read some posts on this in the past and it does not look like anyone has ever been successfull.
What is the best approach? Find a new upper housing and rebuild it?
I the manual I have does not really give the best instructions in removing all the upper housing gears and drive shaft. Is it really hard to do, to put all the guts into a new housing, and if so what tools do I need? I looked at the manauls posted but need more detailed info.
JustJason
Re: Potentiel Expensive Mistake Upper water pocket cover
if you have 3 good bolts and 1 broken 1 I would try installing the cover with the 3 good bolts with dosage of perfect seal underneath of the cover and see how you make out.
It's worth shot before ordering a new drive.
Ayuh,... It's complicated, time consuming,+ the Required Tools will set you back slightly More than the price of a replacement SEI drive...
ziggy
i've made the mistake, and i was successful in the repair.
ya could try the glue like jj says and if that works count your blessings. if not, ya can drill them out. though no easy task and yer only gonna have one shot at it. ya mess up the extraction and ya'll be getting that new drive.
achris helped me out with the idea of making a steel block to guide a drill down the center of the bolt for extraction. i used a 1/2'' thick block of steel and then used the gasket as a guide for drilling pilot holes for my drill bit to run in. i had three broke off. i used the jig for the first two and freehanded the third. the free hand drilled one actually turned out the best, right down the center of the bolt. only thing left of it was the screw threads still in the cast alum.
some notes from memory. 1st, them bolts are stainless steel. one of the harder (material wize) things i've had to drill out. use a very sharp drill bit and go very slow rpms on the drill and use lub. watch for the drill bit cutting the metal. if the metal turns to dust the bit ain't sharp enough. don't even think about drifting off the bolt. you get into the cast aluminum i'll bet your done. i would think it impossible to relocate the center on the bolt if you drift.
you'll need long everything. long drill bits. long tap etc.
my initial goal was to drill and extract the broke off bolt. that didn't work out as mine never got removed and they were corroded in place. i ended up drilling them all the way out to tap size. still didn't work out and ended up going to helicoil size. that worked. tapped for a helicoil and reinstall. if ya get that far, be careful with the tap too. push on it. that cast aluminum is the opposite of the hard ss bolts. ya can't even trust that the tap will be pulled into the alum. when tapping as its so soft you'll just wipe out the screw threads. so push on the tap, if you get that far.
good luck. go slow, make a plan.
bet i spent the better part of 40 hrs easy to get my thing together plus do the deed.
don't know how far the search function goes back, but somewhere in some of my 1st threads was the grief i encountered over that stupid water pocket cover...
