fuzzeywiggler
- Feb 17, 2008
- 357
Pouring foam may be a crucial part of your restoration, as it is required by USCG for all vessels under 21', it may be structural in your boat or just give you piece of mind.
Here is how to pour 2lb or 4lb 1 to 1 mix foam:
Be prepared before hand with all the "mixing" containers you may need I went through all these
Once you have the deck in cut out a bunch of plugs along the stringer (I used a 3" hole saw) the key is to cut out a plug that you can insert later.
Like this
Like this
