power but not enough to get on plane
reestyle
has any one had thiss hapen it planed fine the year before but now it just plows through the water with its nose high in the air lol im not jokin
alden135
Re: power but not enough to get on plane
You'll probably want to post your make and model # if you want help.
rickdb1boat
Is the motor trimmed in when you take off??
Dhadley
It happens every spring. The carbs gummed up sitting all winter and now we're down on power. Don't keep running it, the pistons may suffer big-time.<br /><br />It could be something else but that's usually the scenario.
fireman57
If Dale hasn't nailed it you may have dropped a cylinder. Check for spark but it probably is your carbs.
