Re: Power for 17' Montauk
You can't beat the boat. I've had a '74 model since 1982 and it's still in great shape. I believe the max power it's rated for is 100. I've had two motors on it since I bought it, both 90's and the boat's more than adequately powered. If you're planning on skiing, the 60 is probably a little small but for fishing and running around it should be adequate. Good luck, you can't beat that hull!
