Re: Power heads useable on a 1954 johnson 10hp (QD-15)
Yea, it's best to take yours and match it up. Since the shrouding is completely different, you'll want to make sure that the older one will accomodate the later shroud set up, that is on your 54 model. 54 and later has the wings on the head, for the rear shroud mounts, whereas the 53 had the shroud attached by screws to the powerhead and mounted differently. The 54 and later also had the wings on the front to hold the shroud too.
