power pack repl.
dynedog
How do you test to see if power pack is bad, and if it is will it work partime?
gradytom
Re: power pack repl.
Power pack problems usually manifest themselves in other ways, intermittent performance problems, false alarms etc.
Some testing needs to be done before determining the brain has a problem.
I tested for days on an intermittent water in fuel alarm before sending mine off to DFI Technologies for a rebuild.
When I called them and told the tech what I had tested, he confirmed it was a known power pack failure, I shipped the unit to them and had it sucessfully repaired. No problems since.
What makes you believe you have a power pack problem?
dynedog
48spl hp lacks power acts like going to shut off,checked fuel system cleaned carbs do not know what else to try.
dynedog
have spark motor runs ok than acts like it going to shut off than comes back to speed .
